Add MXD as group layer instead of map
2307
12-19-2019 02:15 AM
MaxMax2
I'm trying to prevent Pro from importing MXD as new map. I want to insert content of the document as a group layer within current map.
What I tried:
var item = ItemFactory.Instance.Create("doc.mxd");
var currentMap = MapView.Active.Map;
var map = await QueuedTask.Run(() => MapFactory.Instance.CreateMapFromItem(item));
    var groupLayer = LayerFactory.Instance.CreateGroupLayer(currentMap, 0, map.Name);
    foreach (var layer in map.Layers)
        groupLayer.MoveLayer(layer, int.MaxValue);
I get exception on line 11:
ArcGIS.Desktop.Mapping.MappingException
HResult=0x80004005
Message=Source layer's container not found.
Source=ArcGIS.Desktop.Mapping
Inner Exception 1:
COMException: Source layer's container not found.
Is it possible to import map as group layer in some way?
Tags (3)
UmaHarano
Hi Max
The MoveLayer on the group layer allows you to move layers within the group of the same layer.
I used copyLayer instead -
                    if (LayerFactory.Instance.CanCopyLayer(layer))
                         LayerFactory.Instance.CopyLayer(layer, groupLayer);
MaxMax2
Hi Uma,
CopyLayer throws:
System.ArgumentException
HResult=0x80070057
Message=Operation on file my_computer_path\AppData\Local\Temp\ArcGISPro11192\F986138A-1986-48FA-AB7D-E5539108F359\Metadata\599ca023c9e23f36f1b3a3e2650c49df.xml failed. Unknown error.
UmaHarano
Hi Max,
Are you able to copy the layers manually?
For example (using the UI) -
* Import the mxd into Pro.
* Open another Map and create a group layer.
* Copy the layers from the mxd imported map to the new group layer in the new map.
Does this workflow succeed?
Also, if you can give me more information on the mxd and the types of layers in it, we can get to the bottom of the problem.
I was able to use your code snippet on a simple mxd I had with a point, line and poly layer. The import and the subsequent copy worked in my test case.
Thanks!
Uma
MaxMax2
I've used for test Business_Analyst_Maplex.mxd from Business Analyst Maplex.mxd. I use Pro 2.3.2, but I think the problem exists in later versions too. Please do tests with the map I pointed to.
UmaHarano
Hi Max
I have informed the Business Analyst team since this happens with this specific data. If you have a reproducible workflow with this, you could also contact technical support.
Thanks!
Uma
