Add-in with MessageBox
1927
10-24-2017 11:21 AM
KarstenRank
Hi there,
how can I write an add-in that shows a Message Box when the project is loaded? I want to give the user some new informations, when he starts a new project?
Karsten
UmaHarano
You can subscribe to the ProjectOpenedEvent (topic9319) to accomplish this.  Additionally, the add-in will need to load as soon as Pro launches, so you will have to set the "autoload" attribute to true in the config.daml of the  add-in.  Code snippets below:
In the Module class of the add-in:
 protected override bool Initialize()
            ProjectOpenedEvent.Subscribe(OnProjectOpened); //subscribe to event
            return base.Initialize();
        private void OnProjectOpened(ProjectEventArgs obj)
            MessageBox.Show($"{Project.Current} has opened"); //show your message box
        protected override void Uninitialize()
            ProjectOpenedEvent.Unsubscribe(OnProjectOpened); //unsubscribe
            return;
In your config.daml, set the autoload attribute to true so that the add-in loads when Pro launches:
 <modules>
    <insertModule id="SubscribeProjectLoad_Module" className="Module1" autoLoad="true" caption="Module1">
Thanks
Uma
UmaHarano
            return;
 <modules>
Thanks
Uma
