Add-In version conflict
2807
03-11-2025 04:47 AM
sonj
We upgraded the tool from 2.9 to 3.4 and working fine in the development system but failed while loading in the test system. The error says "The add-in cannot be loaded because it targets and incompatible version of ArcGIS Pro. Current verion 3.4 add-in targets:2.9"
See the attachment for a better understand.
RichardDaniels
MVP Regular Contributor
win10-x64 is not supported with Visual Studio 2022 and .Net 8.0.12, use win-x64 instead.
KenBuja
MVP Esteemed Contributor
Did you follow all the steps on the migration page from the documentation?
RichardDaniels
three possibilities:
1. Did you update your config.daml to target version 3.0 and higher?
<AddInInfo id="{Your GUID}" version="3.0" desktopVersion="3.4.0">
2. In  your .csproj file for your solution ensure the following tags are updated to:
<TargetFramework>net8.0-windows</TargetFramework>
<RuntimeIdentifier>win-x64</RuntimeIdentifier>
3. ArcGIS Pro requires .Net Desktop Runtime 8.0.x, this must be on both your build and deploy machines. Also, all .Net references in you Visual Studio project need to be updated to use 8.0.x -or .Net 4.8 for any  WinForms.
and
4. run the upgrade tool as referenced by KenBuja
sonj
#1 <AddInInfo id="{GUID}" version="1.0" desktopVersion="3.4.55405">
#2 <TargetFramework>net8.0-windows7.0</TargetFramework>
<RuntimeIdentifier>win10-x64</RuntimeIdentifier>
#3 Project->Properties->Target Framework -> .NET 8.0
#4 Downloaded and installed below
  • ArcGIS Pro SDK for .NET,
  • ArcGIS Pro SDK for .NET (Utilities)
  • ArcGIS Pro SDK for .NET (Migration).
RichardDaniels
sonj
Thanks @RichardDaniels, it worked after changing to win-x64.
