Add file to My Content (Add item) to AGOL
715
06-29-2023 07:39 AM
RejeanLabbe
I would like to add a file (an image in my case) to My content on AGOL.
In the ArcGISOnlineConnect project from ArcGIS Pro SDK Community Samples, we can run queries with Rest API.
We can get an item with this call :
"/sharing/content/items/{0}?f=pjson;Item;<Enter an ArcGIS Online Item Id>"
The code goes like that :
private void CmdDoQuery()
            try
                var httpEsri = new EsriHttpClient() { BaseAddress = ArcGISPortalManager.Current.GetActivePortal().PortalUri };
                // value has the following format: url with {};Redlands,...,...;Search Query,...,...
                // where Redlands ... are values and search query are keys
                var parts = AgolQuery.Value.Split(";".ToCharArray());
                var getUrl = parts[0];
                // get parameters
                if (CallParams.Count > 0)
                    var lstParams = new List<object>() as IList<object>;
                    foreach (var kv in CallParams)
                        lstParams.Add(kv.Param);
                    getUrl = string.Format(parts[0], lstParams.ToArray());
                System.Diagnostics.Debug.WriteLine(getUrl);
                var httpResponse = httpEsri.Get(getUrl);
                if (httpResponse.StatusCode == HttpStatusCode.OK && httpResponse.Content != null)
                    var content = httpResponse.Content.ReadAsStringAsync().Result;
                    QueryResult = string.Format(@"{0}{1}", getUrl, System.Environment.NewLine);
                    QueryResult += string.Format(@"IsSuccessStatusCode: {0}{1}", httpResponse.IsSuccessStatusCode, System.Environment.NewLine);
                    QueryResult += string.Format(@"StatusCode: {0}{1}", httpResponse.StatusCode, System.Environment.NewLine);
                    QueryResult += content;
                    if (AgolQuery.Key == ArcGISOnlineQueries.AGSQueryType.GetSelf)
                        _AgolUser = AgolUser.LoadAgolUser(content);
                    else if (AgolQuery.Key == ArcGISOnlineQueries.AGSQueryType.GetSearch)
                        _AgolSearchResult = AgolSearchResult.LoadAgolSearchResult(content);
                    else if (AgolQuery.Key == ArcGISOnlineQueries.AGSQueryType.GetUserContent)
                        _AgolUserContent = AgolUserContent.LoadAgolUserContent(content);
                        _AgolFolderContent = null;
                    else if (AgolQuery.Key == ArcGISOnlineQueries.AGSQueryType.GetUserContentForFolder)
                        _AgolFolderContent = AgolFolderContent.LoadAgolFolderContent(content);
                    System.Diagnostics.Debug.WriteLine(QueryResult);
            catch (Exception ex)
                QueryResult = ex.ToString();
I assume there is and additem end point that allow us to send a file and retrieve the new created id.
Any help would be apprecieated.
MK13
Did you ever figure this out?
RejeanLabbe
No, sorry
