Add a raster (.tif) to the active map using .NET SDK for ArcGIS Pro
2359
09-20-2023 08:25 AM
nadja
this might be an absolute basic question, but how do I add a raster to an active map so that it is listed in the table of content and visible in the map?
I managed to create an empty map, which is then under MapView.Active.Map. when I try to add a simple .tif raster to this map, I fail. I tried various code snippets, but none works for me. the .tif rasterfile is currently in my local directory.
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Raster I found this code snippet (Open raster dataset in a folder), which works as it doesnot raise an error. But it doesn't add the created raster to the map either. So I'm guessing that I need to add it specifically.
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic11851.html the docu suggests a RemoveLayer method. but I cannot find a addRaster or addLayer method. how is this done??
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Map-Authoring/AddRasterLayer I also found this example, but I really don't see/get where they are adding the raster..
thanks for any help
Tags (3)
GKmieliauskas
Take a look at the ArcGIS Pro SDK API reference
string url = @"C:\Images\Italy.tif";
await QueuedTask.Run(() =>
  // Create a raster layer using a path to an image.
  // Note: You can create a raster layer from a url, project item, or data connection.
  rasterLayer = LayerFactory.Instance.CreateLayer(new Uri(url), aMap) as RasterLayer;
Or modify sample from your last link
                // The layer has to be created on the Main CIM Thread (MCT).
RasterLayer rasterLayer = null;
                  // Create a layer based on the url. In this case the layer we are creating is an image service layer.
                  var layerParams = new LayerCreationParams(new Uri(url));
                  rasterLayer = LayerFactory.Instance.CreateLayer<RasterLayer>(layerParams, myMap);
                  // Check if it is created.
                  if (rasterLayer == null)
                      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Failed to create layer for url:" + dataSoureUrl);
                      return;
GKmieliauskas
                      return;
