Activate / Deactivate custom Add-In for Enterprise Credentials in ArcGIS Pro.
1831
06-25-2024 05:07 AM
Muhammad_Elbagoury
Hello All,
I created a custom Add-In with number of groups and buttons.
I want to activate this add-in with all groups and buttons only if I am logged in to ArcGIS Pro using ArcGIS Enterprise credentials.
Please support,
Thank you.
Tags (3)
UmaHarano
You can use states and conditions.
  • Pro has an internal state defined by this id: esri_core_isSignedIn
  • You can create your own custom condition using this state. New conditions are defined in daml.
  • Then add this condition to your controls.
In DAML, create this condition:
 <conditions>
      <insertCondition id="my_condition_Online">
	 <and>
	   <state id="esri_core_isSignedIn" />
	 </and>
      </insertCondition>
 </conditions>
</ArcGIS>
Then, add this condition to your control. Like this in config.daml
<tab id="EsriCommunity_Tab1" caption="New Tab" condition="my_condition_Online">
UmaHarano
 <conditions>
	 <and>
	 </and>
      </insertCondition>
 </conditions>
</ArcGIS>
Muhammad_Elbagoury
Thank you for your support.
This worked, the tab is already visible while Pro is signed in.
What if I want to customize this signed in state to be only for Enterprise (not for public account or even Online Organization) ??
VedantBajaj
public class SignInChecker
    public static bool CheckSignInArcGISOnline()
        bool signIn = false;
        signIn = QueuedTask.Run(() =>
            // Get the active portal
            var activePortal = ArcGISPortalManager.Current.GetActivePortal();
            // Check if the active portal is ArcGIS Online or ArcGIS Enterprise
            if (activePortal != null)
                var user = activePortal.GetSignOnUsername();
                if (string.IsNullOrEmpty(user))
                    Console.WriteLine("User is not signed in.");
                    return false;
                else
                    var portalUri = activePortal.Uri;
                    if (portalUri.Host.Contains("arcgis.com"))
                        Console.WriteLine($"User is signed in to ArcGIS Online as: {user}");
                        return true;
                    else
                        Console.WriteLine($"User is signed in to ArcGIS Enterprise as: {user}");
                        return false;
            else
                Console.WriteLine("No active portal found.");
        return signIn;
Hi @Muhammad_Elbagoury ,
You can implement your own state/condition and use a function like this to determine if user is logged on to ArcGIS Online or Enterprise.
We have some Framework Concepts which can help you understand the concepts behind states and conditions:
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Framework#conditions-and-state
Here is a tutorial which can help you guide how you can implement:
https://developers.arcgis.com/documentation/arcgis-pro-sdk/tutorials/manage-the-pro-ui-with-conditio...
RichardDaniels
MVP Regular Contributor
In the appropriate place in the above code example you would then use the .Activate and .Deactivate methods similar to FrameworkApplication.State.Activate("goodLogin_State").
You would also want to us your own state instead of esri's internal predefined state variable.
<state id="goodLogin_State" />
