AccessViolationException in PolylineBuilder
2599
12-05-2016 07:27 PM
MaxMax2
I found that PolylineBuilder throws the AccessViolationException when the builder is used after multiple Dispatcher.Invoke calls. If I use BeginInvoke instead of Invoke, everything goes fine, so it is the workaround. But I believe you should fix this problem.
I've attached VS solution with simple test add-in (TestAddIn.zip) and test data (test.gdb.zip, place it in Debug folder after solution building). This test add-in contains one button (Click Me!) which opens a dialog. In this dialog click the Start button and you'll get AccessViolationException at line #35 in FeatureClassIterator.cs file.
NarelleChedzey
Hi Max,
Thanks for finding this bug and for the clear reproducible case.
We are fixing this issue for the 1.4 release.
Regards
Narelle Chedzey
MaxMax2
Hi Narelle,
I see it is fixed now (1.4). Thank you.
