Reading aptx file
3099
07-09-2020 01:17 AM
by Anonymous User
Not applicable
1 0 3,099
After sometime back I got difficulty on reading aptx file information with ArcPro SDK, refer to this post.
Retrieval of Project/project template metadata
Thank to Wolfgang Kaiser‌, I found out that aptx is actually a 7zip file, and no wonder I can't use build in Microsoft provided zipfile libraries.
And the there are a lot of 7zip extractor out there in nugget space but some are not working properly to extract that aptx file.
Among them, SevenZipExtractor, 7z.NET nugget libraries can extract that aptx file.
Below is the code snippet how we can achieve and extract aptx info.
Model class generated and modified from xml file
using System.ComponentModel;
using System.Linq;
using System.Runtime.CompilerServices;
 // NOTE: Generated code may require at least .NET Framework 4.5 or .NET Core/Standard 2.0.
    /// <remarks/>
    [System.SerializableAttribute()]
    [System.ComponentModel.DesignerCategoryAttribute("code")]
    [System.Xml.Serialization.XmlTypeAttribute(AnonymousType = true)]
    [System.Xml.Serialization.XmlRootAttribute(Namespace = "", IsNullable = false)]
    public partial class ESRI_ItemInformation: INotifyPropertyChanged
        private string nameField;
        private string guidField;
        private decimal versionField;
        private object createdField;
        private object modifiedField;
        private object catalogpathField;
        private string snippetField;
        private object descriptionField;
        private string summaryField;
        private string titleField;
        private string tagsField;
        private string typeField;
        private string[] typekeywordsField;
        private string thumbnailField;
        private object documentationField;
        private object urlField;
        private object spatialreferenceField;
        private decimal minScaleField;
        private decimal maxScaleField;
        private object datalastModifiedTimeField;
        private object accessinformationField;
        private object licenseinfoField;
        private string cultureField;
        /// <remarks/>
        public string name
            get
                return this.nameField;
            set
                this.nameField = value;
                this.NotifyPropertyChanged();
        /// <remarks/>
        public string guid
            get
                return this.guidField;
            set
                this.guidField = value;
        /// <remarks/>
        public decimal version
            get
                return this.versionField;
            set
                this.versionField = value;
        /// <remarks/>
        public object created
            get
                return this.createdField;
            set
                this.createdField = value;
        /// <remarks/>
        public object modified
            get
                return this.modifiedField;
            set
                this.modifiedField = value;
        /// <remarks/>
        public object catalogpath
            get
                return this.catalogpathField;
            set
                this.catalogpathField = value;
        /// <remarks/>
        public string snippet
            get
                return this.snippetField;
            set
                this.snippetField = value;
        /// <remarks/>
        public object description
            get
                return this.descriptionField;
            set
                this.descriptionField = value;
        /// <remarks/>
        public string summary
            get
                return this.summaryField;
            set
                this.summaryField = value;
        /// <remarks/>
        public string title
            get
                return this.titleField;
            set
                this.titleField = value;
        /// <remarks/>
        public string tags
            get
                return this.tagsField;
            set
                this.tagsField = value;
        /// <remarks/>
        public string type
            get
                return this.typeField;
            set
                this.typeField = value;
        /// <remarks/>
        [System.Xml.Serialization.XmlArrayItemAttribute("typekeyword", IsNullable = false)]
        public string[] typekeywords
            get
                return this.typekeywordsField;
            set
                this.typekeywordsField = value;
        /// <remarks/>
        public string thumbnail
            get
                return this.thumbnailField;
            set
                this.thumbnailField = value;
        /// <remarks/>
        public object documentation
            get
                return this.documentationField;
            set
                this.documentationField = value;
        /// <remarks/>
        public object url
            get
                return this.urlField;
            set
                this.urlField = value;
        /// <remarks/>
        public object spatialreference
            get
                return this.spatialreferenceField;
            set
                this.spatialreferenceField = value;
        /// <remarks/>
        public decimal minScale
            get
                return this.minScaleField;
            set
                this.minScaleField = value;
        /// <remarks/>
        public decimal maxScale
            get
                return this.maxScaleField;
            set
                this.maxScaleField = value;
        /// <remarks/>
        public object datalastModifiedTime
            get
                return this.datalastModifiedTimeField;
            set
                this.datalastModifiedTimeField = value;
        /// <remarks/>
        public object accessinformation
            get
                return this.accessinformationField;
            set
                this.accessinformationField = value;
        /// <remarks/>
        public object licenseinfo
            get
                return this.licenseinfoField;
            set
                this.licenseinfoField = value;
        /// <remarks/>
        [System.Xml.Serialization.XmlAttributeAttribute()]
        public string Culture
            get
                return this.cultureField;
            set
                this.cultureField = value;
        public event PropertyChangedEventHandler PropertyChanged = delegate { };
        private void NotifyPropertyChanged([CallerMemberName] string propName = "")
            PropertyChanged(this, new PropertyChangedEventArgs(propName));
Real fun part extract and load into object, later part you can freely play with object
For below sample, I am using NuGet Gallery | SevenZipExtractor 1.0.15
ESRI_ItemInformation TemplateInfo ;
using (ArchiveFile archiveFile = new ArchiveFile(templatePath))
                Entry itemInfoEntry = archiveFile.Entries.FirstOrDefault(x => x.FileName.Equals(@"esriinfo\iteminfo.xml", StringComparison.OrdinalIgnoreCase));
                if (itemInfoEntry != null)
                    MemoryStream memoryStream = new MemoryStream();
                    itemInfoEntry.Extract(memoryStream);
                    memoryStream.Position = 0;
                    XmlSerializer serializer = new XmlSerializer(typeof(ESRI_ItemInformation));
                    TemplateInfo = (ESRI_ItemInformation)serializer.Deserialize(memoryStream);
Tags (1)
