Zooming in to 1:1 issues
7098
11
08-08-2018 08:38 AM
by Anonymous User
Not applicable
I am working with a floor plan and when I start zooming in to 1:1 the line features don't display correctly.
I've attached 3 screen shots of what is happening. when I am out at 1:25 everything is normal. Once I start to get closer at 1:4 things start to get a little wonky then at 1:1 they get even more weird. when I select the features the selection is correct.
Is there a fix for this?
KoryKramer
Esri Esteemed Contributor
Glad there are no issues when projecting on the fly!  I just ran a quick test with my own data in UTM 17N in a map in WGS84 web mercator auxiliary sphere and don't see the issue.  I understand that you're not able to share the data but in this case I think we would need to get it to investigate this further.
Could you share just the geometry with no attributes?  And just the small subsection that demonstrates the display issue?
ThomasColson
MVP Alum
FWIW, I get this often in Arc to, and is a function of geometry complexity. Key question here, is that open door thingy a true Bezier Curve, or a line with many vertices? Can you "densify" it if it is Bezier, convert it to a line with many vertices, same behavior? What about a simple dataset, say, just two lines intersecting?
