I am working with a floor plan and when I start zooming in to 1:1 the line features don't display correctly.
I've attached 3 screen shots of what is happening. when I am out at 1:25 everything is normal. Once I start to get closer at 1:4 things start to get a little wonky then at 1:1 they get even more weird. when I select the features the selection is correct.
Is there a fix for this?
What is the actual physical dimensions (not the scale)?
Is the line actually a segmented sequence of lines? or is it how it is being shown?
That object is a door from a building blue print, it's 1.03m long
the line is a single segment
I have seen display issues when you are in past 1:10. There is nothing necessarily wrong/incorrect with the data, you are just zoomed in past what is usable and what the tolerances are set to. When this happens, it causes the displayed data to show weirdness, as you are seeing.
I do not think that this is a defect but more of a display issues when zoomed into such a large scale like 1:1.
Is there a reason that you are zoomed in that close?
looks like a display issue, but I suspect that you will have to provide more info as to what file type it is (ie geodatabase featureclass, a cad layer etc etc).
not many people are working at that scale, so I will flag Kory Kramer to see if he knows who to pass this on to
Is the data projected? If so, what is the projection?
And yes, what is the data format? Can you share the data, or even just this little section where you're seeing the issue?
I was trying to fix some topological errors
The data is stored in a file geodatabase as a feature class which is in NAD 83 and the map is in web Mercator.
unfortunate I am unable to share this data due to privacy concerns.
I did notice that when I put the map into the same coordinate system as the feature classes the display error goes away.
NAD83? What was the specific projection? So when the data isn't being projected on the fly, there is no issue at 1:1, correct?
NAD 83 CSRS UTM zone 17NYes when not projecting on the fly there is no issue.
Glad there are no issues when projecting on the fly! I just ran a quick test with my own data in UTM 17N in a map in WGS84 web mercator auxiliary sphere and don't see the issue. I understand that you're not able to share the data but in this case I think we would need to get it to investigate this further.
Could you share just the geometry with no attributes? And just the small subsection that demonstrates the display issue?
FWIW, I get this often in Arc to, and is a function of geometry complexity. Key question here, is that open door thingy a true Bezier Curve, or a line with many vertices? Can you "densify" it if it is Bezier, convert it to a line with many vertices, same behavior? What about a simple dataset, say, just two lines intersecting?
