Zonal remap raster function - can't enter zonal attributes table
7011
14
03-01-2021 02:01 PM
MikeShelley
I'm trying to reclassify raster cell values based on where they intersect another raster. The primary raster classifies vegetation type, and I would like to overlay a second raster that classifies wildfire severity, then use the Zonal Remap function to change the vegetation type based on the wildfire severity (where areas of high fire severity exist, change vegetation cell values from "forest" to "grassland").
It seems like the Zonal Remap raster function would be the way to accomplish this, but I would love to hear if there is a more appropriate tool!
When setting up the Zonal Remap tool, I can't seem to enter a table into the field marked "Zonal Attributes Table" (see attached screenshot). There is no drop-down menu available to select a table, and I can't drag/drop a table from the Table of Contents or the Catalog pane into the field. Am I missing something? I'm using ArcGIS Pro 2.7.1
KoryKramer
Esri Community Moderator
Dan, are you able to paste the path in that box?  That is the workaround.
While this will also be improved in the help, good point about that not showing for each parameter (like it does for GP tools).  I'll bring that up as well.
MikeShelley
I tried pasting the file path, but after running the tool it doesn't appear that any changes have occurred.
I also tried following the link that Dan provided, to subscribe to the bug report, but hit the same 404 error that he posted a screenshot of. The link worked yesterday afternoon, but not anymore...
DanPatterson
@MikeShelley give it a go with your data.
@KoryKramer
Updating with the workaround?   It has been sometime that it was originally filed
... sort of retired...
KoryKramer
When an update is made that is public, it goes through a brief copy review stage.
DanPatterson
In Production Plan
Alternate solution
Paste the path into the Zonal Attributes Table parameter rather than trying to browse to it.
Updated as of March 2nd
