Year zero problem when applying asset package
1755
10-02-2018 07:35 AM
TheodoreRakel
I am using Pro 2.2.2 and trying to run the GP tool 'apply asset package' and load data.  I get the following error that 'year 0 is out of range'.  Is there any way to find out what date is causing this problem?  I looked at the data in the asset package and all the dates I find are from Sep 2018.  If I run 'apply asset package' and do not load the data, then the GP successfully completes.
Start Time: Friday, September 28, 2018 8:17:57 AM
Running script AssetPackageToUtilityNetwork...
ArcGIS Pro 2.2.2.12813
untools 2.2.0
A python error occurred.
EXCEPTIONTraceback (most recent call last):  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\common\wrappers.py", line 84, in wrapper    return func(*args, **kwargs)  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\gptools\tools.py", line 258, in run    un = UtilityNetworkTools(utility_network)  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\utils\utility_network.py", line 31, in __init__    self.refresh()  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\utils\utility_network.py", line 87, in refresh    self.cache['describe'] = un_helper.Helper(self._un)  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\un_helper.py", line 1232, in __init__    super().__init__(utility_network)  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 845, in __init__    self.domainNetworks = [DomainNetworks(x) for x in d.domainNetworks or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 845, in <listcomp>    self.domainNetworks = [DomainNetworks(x) for x in d.domainNetworks or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 524, in __init__    self.tiers = [Tiers(x) for x in d.tiers or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 524, in <listcomp>    self.tiers = [Tiers(x) for x in d.tiers or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 450, in __init__    self.aggregatedLinesForSubnetLine = [AssetGroups(x) for x in d.aggregatedLinesForSubnetLine or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 450, in <listcomp>    self.aggregatedLinesForSubnetLine = [AssetGroups(x) for x in d.aggregatedLinesForSubnetLine or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 305, in __init__    self.assetTypes = [AssetTypes(x, source) for x in d.assetTypes or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 305, in <listcomp>    self.assetTypes = [AssetTypes(x, source) for x in d.assetTypes or []]  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 260, in __init__    self.creationTime = convert_time(getattr(d, 'creationTime', None))  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\untools\abstract\describe.py", line 51, in convert_time    return dateutil.parser.parse(stamp)  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\dateutil\parser\_parser.py", line 1356, in parse    return DEFAULTPARSER.parse(timestr, **kwargs)  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\dateutil\parser\_parser.py", line 653, in parse    ret = self._build_naive(res, default)  File "C:\Users\pe_gis\AppData\Local\ESRI\conda\envs\UN-environment\lib\site-packages\dateutil\parser\_parser.py", line 1227, in _build_naive    naive = default.replace(**repl)ValueError: year 0 is out of range
Failed to execute (AssetPackageToUtilityNetwork).
Failed at Friday, September 28, 2018 8:18:04 AM (Elapsed Time: 7.45 seconds)
Tags (1)
TheodoreRakel
I submitted a case to esri about this and found that the connection I was using when running the 'Apply Asset Package' GP tool needed to have its geodatabase connection properties set to use 'Traditional' versioning.  I had it set to use 'Branch' versioning.  I ended up deleting the Utility Network dataset and running 'Stage Utility Network' GP tool again.  Then I ran 'Apply Asset Package' and loaded the data successfully.
PaulLeBlanc1
This looks like a timestamp in the UN that is causing the issue. This error occurs when reading the UN (though that doesn't explain why you don't get the error when not loading data).
TheodoreRakel
