xy table to point
1666
07-23-2021 03:43 AM
DamienHaberlin
When I call the 'xy table to point' tool and select the browse icon, ArcGIS pro freezes completely and is unresponsive. I have to use 'end task' to force shut down the programme. This happens regardless of which project I open.
Running ver. 2.8.1. on an a MS windows 10 machine. 32 GB ram, dell i7. It's a well spec'd laptop.
Any help is appreciated.
JayantaPoddar
Check if performing a soft-reset works? You could follow the steps in https://support.esri.com/en/technical-article/000024975
Think Location
DamienHaberlin
Thanks for that, it appears to have fixed the problem.
Much appreciated!
DanPatterson
MVP Esteemed Contributor
does it freeze with all tools?
Is it a geodatabase table? excel? csv?
Have you tried adding the table to a local file geodatabase first? then try the tool?
... sort of retired...
DamienHaberlin
Hi Dan
Yes, it was freezing with other tools as well. Any attempt to browse to an input file seemed to trigger a complete freeze.
