Write RGB rasters to pdf using arcpy in Arcgis Pro 3.x
866
01-19-2023 11:09 AM
WadeWall
Hi all,
I would like to write a collection of RGB rasters located in a folder to a single pdf, with one raster per image. I see that a methodology is outlined here:
https://community.esri.com/t5/python-questions/export-multiple-raster-into-single-pdf-using-arcpy/td...
However, this is for arcmap 10.x. I am wanting to go through a collection of rasters, loading each one individually into a layout, and then print the layout to a pdf, and then remove the raster before adding the next. Is it possible to do this in Arcgis Pro / arcpy? If anyone could point me in the right direction, I would greatly appreciate it.
Taren_Esri
Hi @WadeWall
This is possible. I can't necessarily write the code out here for you, but most of what you want can be accomplished with a few iterators, and the Layout object. The documentation for this is really robust, and if you Ctrl + F "PDF" you can get some more information on the Export to PDF method, in addition to a good rundown of what other objects you'll need to get setup. Good luck!
WadeWall
Thanks for pointing me in the right direction.
