Working with Legends
3659
6
03-24-2016 12:54 PM
AmeliaNewsam
I am trying to get rid of the Field and layer names in the Legend.  I did read the section of the online help about this, but could not find a solution other than converting to graphics.  Is there a way to do this without converting to graphics?
DanPatterson_Retired
That is the easiest solution, and takes only a few seconds.
DavidBarnes
Yes, you can turn off the different legend labels. To do that you will need to select legend items in the Contents pane under the legend (don't get that confused with the layers in the map). Then open the properties pane and you will find checkboxes to turn off the headings, etc. Note: you can do this for multiple items at once by selecting multiple legend items in the Content pane, using the Shift key and/or Ctrl key to multi-select.
AmeliaNewsam
OK, so I do not see any legend items in my Contents pane. That is what was
confusing me in the instructions. There is nothing to click on.
AmeliaNewsam
Oh dear, I just realized there is a little expand arrow to the left of the
Legend in the Contents pane. so sorry to have wasted your time!
DavidBarnes
No worries. I almost mentioned you might have to expand the legend in the Contents pane. Glad you figured it out!
BobChristensen
Hi Appreciate this thread but I am unable to turn off multiple items in the legend using Shift/Cntrl in the same way I can turn off multiple items in the map layers. I am using version 2.1.2.
Thanks!
