Working with a Map Layout
1120
08-22-2024 12:11 PM
GeorgeDeYonge
Good afternoon!
I'm using ArcGIS pro version 3.3.52636 to work on a Map for a WFO project. I've chosen a custom layout (see attached screenshot below), and I'd like to know how to place the 2 points i've created (AB-2021-004, and AB-2021-062, into the square box on the bottom left of my map layout, next to my map title. I've tried zooming in and out of the map layout, but I'm unsure on how to place those points of the map layout in that box to capture them in a clear focus.
Thank you for any help/feedback regarding this post!
Sincerely,
George DeYonge
AubriOtis
Hi! What a cool map and layout. The first thing to do is check that the small map frame is pointing to the correct map (the one with the points). If it isn't you can change the map in the map frame to the correct one. Once you've verified that, you can activate the map frame and zoom in. I think that should give you what you are looking for. This help topic has great information on how to activate a map frame and make changes on a layout: https://pro.arcgis.com/en/pro-app/latest/help/layouts/work-with-a-map-on-a-layout.htm
Cheers,
Aubri
