What is a good way to convert shapefiles to geodatabases in Pro? Can it be done as a batch? I keep ending up with a shapefile copy in my destination folder since there is no option to designate this file type.
I would prefer not to use Map, that's what I am doing for now. It seems there has to be a way to get this to work, the Pro documentation promises it.
Are you using a Copy Paste technique in the Catalog view where you end up with a copy of the shapefile?
How about Exporting the Shapefile to a file gdb either from the Catalog view or the Contents pane of Pro.
I was using the feature class to geodatabase tool. I am instead using
data, export data in Map since that defaults to file gdb without much user
intervention. The folder structure is fairly deep and has unique file
names for point and polygon parcels, so I think writing a script would take
about as long as exporting 100 counties.
Joshua, how can I designate this tool to output file geodatabases? Or is
that not possible?
It sounds like the Feature Class to Geodatabase GP tool is defaulting to your Default.gdb that's buried in a Window's folder structure. What I would do is create a new file geodatabase in a project folder (in the Catalog window, right click in the folder you where you want the *.gdb to be stored and select New File Geodatabase), then run the Feature Class to Geodatabase GP tool with output geodatabase being the newly created file geodatabase. Make sense?
Or if you have a ton of shapefiles - Modelbuilder using an Iterator for the Feature Class to Geodatabase GP tool!
