Why isn't my script returning any values in Modelbuilder?
1459
04-21-2022 09:11 AM
LR2
I want to output some variables for further use in ModelBuilder, however the parameters always end up empty. What's wrong?
LR2
The message window from the modeler already shows everything at level 0. Returning values also doesn't work. However what does is
    arcpy.SetParameter(2,PR_Out)
    arcpy.SetParameter(3,PID_Out)
DanPatterson
MVP Esteemed Contributor
nothing is returned by the function, you could build up a msg, then use it as a return object to print when it exits the function
Also
GetMessages—ArcGIS Pro | Documentation
doe that appear anywhere in your script?
... sort of retired...
LR2
