why feature dataset doesn't show up in Catalog pane of ArcGIS pro
1832
07-11-2018 12:51 PM
GeorgeShi2
I have a feature dataset and a few feature class in an SDE. the feature dataset and its feature classes show in ArcCatalog fine. however, the feature dataset doesn't show in ArcGIS pro's catalog pane when I use the same .sde connection file. Any hints?
Tags (1)
George_Thompson
Esri Notable Contributor
What is the RDBMS being used, what ArcMap version and what version of Pro?
What version is the geodatabase at?
Can you provide 2 screenshots also?
--- George T.
DávidGregor
I have similar problem. ArcGIS Pro 2.4 with Oracle database connection with 2800 tables. I can see all of the tables in Catalog View, but not in Catalog Pane. Feature or bug? Any hidden setting?
