Why does the "Create Features, Create Points Along Line" feature edit function display an inconsistent line length.
2314
04-20-2020 08:45 PM
JozefMeyer
I have a line feature with an attribute length of 1591.419492, measuring the line gives the same value but in meters. When I use the "Create Points Along Line" function under editing it states the length of the line is 0.013m.
Any idea what I'm doing wrong?
Scott_Harris
Hi Jozef,
I'm not reproducing this:
What coordinate system is your line layer?
What coordinate system is the map?
Is this the only data you have that reproduces the issue?
Scott
Scott_Harris
Hi Jozef,
Scott
JozefMeyer
Ah that's it! There was a sneaky transformation I didn't see when I checked the coordinate systems. Thanks for your help.
ScottJones1
What was the solution?
eotwmapping
Hello @JozefMeyer
Do you happen to know what you did to fix this issue?  I am currently running into the same issue and do not understand what I am doing wrong.
Thanks
ScottJones1
I think, I was bringing various features in different DATUMS, it took a minute but I was able to find the best DATUM for my area, then did a transformation to that DATUM... my biggest mistake is being self taught so I never truly learned the importance of PROJECTING data correctly
