Which measurement do I want in ArcGIS Pro? Path, Sum or Segement or the Net Path at the bottom? I am trying to measure a pathway from the entrance of a building to the nearest bus stop.
1050
06-18-2020 01:50 AM
JasBerrill
DanPatterson
MVP Esteemed Contributor
I would start with Path, since it seems to be the longest
... sort of retired...
EcofishResearch
Hi!
Path is the distance you have measured this round, while sum includes measurements from the whole session. If you use the erase button and try again, your sum and path will be equal.
