Where to 'close parenthesis'?
3172
12-21-2022 09:52 AM
Philip_Ruthstrom
A relative beginner here in Arcade, as well as to posting questions on forums, but I can't find a solution for this particular issue...
I'm working in ArcPro, attempting to build a table using the Insert Table Attribute/Dynamic Text Element with a custom Arcade expression (Arcade being the only choice available). My first task is to remove or reduce duplicate Project_IDs that are paired with associated Site_IDs. Being familiar with Javascript, I tried several methods such as reduce() and forEach(), but kept ending up with the same error:
'Invalid expression. Error on line 6. Close parenthesis expected'
There are no syntax errors detected using VS Code, etc. And yet I'm at a loss...
Here's the code as it is now:
var pID = [$feature.PROJECT_ID];
function removeDuplicates(pID) {
var unique = [];
for(i=0; i < pID.length; i++){
if(unique.indexOf((pID[i]) === -1)){
unique.push(pID[i])
return unique;
return removeDuplicates(pID);
KenBuja
MVP Esteemed Contributor
There are some syntax differences in Javascript and Arcade code. Here's a revised version showing those differences ("==" instead of "===", "Count" instead of "length", and the IndexOf and Push syntax).
  var unique = [];
  for(var i=0; i < Count(pID); i++){
    if(IndexOf(unique, (pID[i])) == -1){
      Push(unique, pID[i])
  return unique;
Philip_Ruthstrom
Ah, I figured there were some key differences between the two. The changes you made do 'solve' the error, however it returns only a delimiter for each record, while removing none of the duplicates.
KenBuja
What does your data look like? That would make it easier to figure out how to return the unique values.
Philip_Ruthstrom
I have a list of Project_IDs that have one or more Site_IDs, and I'm trying to list the sites under their respective projects (projectA -> Site1, Site2) instead of listing them individually (projectA -> Site1, ProjectA -> Site2)
I'll apply the changes you detailed earlier to the other methods I tried and see if it comes up with anything different.
