Where to change LogEntryType for ArcGIS Pro?
941
11-18-2020 02:08 PM
DannyMac
In %USERPROFILE%\AppData\Local\ESRI\ArcGISPro\Staging\SharingProcesses folder there is a file called SharingMainLog.xml.  In that file you will find an entry for every publish job. One of the attribute values for a job is the LogEntryType, which seems to default to Info.  I'm assuming this is the log level.
Does anyone know how to change the LogEntryType to Debug or Trace level in ArcGIS Pro prior to publishing so we can get more details about where a failure is occurring in the publish process?  Info level logging is not providing enough detail about failures.
