Where is in_memory\feature_set?
1519
02-24-2023 07:52 AM
coolflippers
I just ran ready-to-use elevation-profile. Output doesn't appear, instead the View Details says it went to in_memory\feature_set. Where is that? I opened a fresh project, and it worked fine.
Robert_LeClair
Esri Esteemed Contributor
Interesting.  I opened an existing project, ran the Ready To Use Elevation Profile tool and it went to my Project Geodatabase as a feature set.   Not in-memory at all.  What release of ArcGIS Pro are you using?  I'm using 3.0.4
coolflippers
I am working in a school environment, hybrid-cloud sort-of, so I'm not surprised I ran into an in-memory operation. I read over the help file Duncan recommended below, but maybe I need to read it a bit slower, because it didn't directly get to the answer.
DuncanHornby
MVP Notable Contributor
Suggest you read the help file on this topic.
