Where can you use SQL beyond WHERE clauses in a File Geodatabase?
1813
12-06-2024 06:33 AM
AZendel
I just ran across this help topic while researching a related issue: File geodatabases SQL reference. This has a lot of potential to be very handy. Where can you execute these statements that use concepts such as aggregations and joins? Is there somewhere in the Pro interface that I haven't noticed? In some geoprocessing tools? Or only in the FGDB API?
Asrujit_SenGupta
In a View comes to mind immediately: Create Database View (Data Management)
Check this for more uses: SQL reference for query expressions used in ArcGIS
In ArcGIS Pro, SQL expressions can be used in the following tools and locations:
Not sure if all the above are applicable for a File gdb, but this gives you an idea.
JoshuaBixby
MVP Esteemed Contributor
Thorough response, nice.  (Assuming generative AI didn't do it for you, but then maybe I should be impressed if it did)
Asrujit_SenGupta
😁Nah, all the info is from the second link directly.
KenBuja
You can use these in Arcade functions (Distinct, Filter, GroupBy, etc)
