When you run Extract Values to Points tool on the ESRI Terrain service layer, where are the output values from and how can you determine the source?
901
01-20-2022 02:24 PM
by Anonymous User
Not applicable
The Overview page states "The ground heights are based on multiple sources." and lists sources as "Credits (Attribution) Source: Airbus, USGS, NGA, NASA, CGIAR, NLS, OS, NMA, Geodatastyrelsen, GSA, GSI and the GIS User Community".
So if I extract values, how can I tell what the source was? You can do a definition query on the layer, but that's not a helpful solution in all cases. Is that the only solution?
This is a generalized repost from this question for more precise search term visibility.
by Anonymous User
Not applicable
Although not for Pro, this describes using definition queries to select a specific elevation type.
https://doc.arcgis.com/en/data-appliance/7.0/use/use-world-elevation-services.htm
This is a similar Pro version.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/appendices/geoprocessing-considerations-for-...
In my reading, the docs don't answer the original question. If you aren't using a definition query, where do the values come from?
