When measuring a line, what coordinate system does the Measure Distance tool use?
2378
06-13-2022 03:38 PM
by Anonymous User
Not applicable
ChristopherCounsell
MVP Frequent Contributor
The measure tool uses the Coordinate System set in the Map Properties.
You can confirm this by measuring the distance between two cities and then changing the map coordinate system.
It's what they use in introduction to ArcGIS courses to explain the distortion on projections.
DanPatterson
MVP Esteemed Contributor
Measure—ArcGIS Pro | Documentation
lots of options, including planar and geodesic, read the topic for 2D and 3D options for maps and scenes
... sort of retired...
by Anonymous User
Not applicable
Unless I missed something, the only mention of coordinate systems on that page is for measuring area. And that section has no mention of which coordinate system is actually used.
I'm trying to figure out how ArcPro determines which coordinate system to use for the measurement.
ChristopherCounsell
ssrojas
I was also wondering about this! I turned off all layers in ArcGIS Pro and used the measuring tool...Still got a measurement. So, I assumed it was from the Coordinate System.
