Web Share Stuck in a Loop
2785
04-04-2024 10:13 AM
ThomasGoodridge
I'm trying to upload a mosaic to arc online from pro 3.2.2 and it's just gets stuck on "Consolidating data and staging web layer" for 8 hours and then stops.
RhettZufelt
MVP Notable Contributor
Under the Options drop down, did you by chance select "Cache Locally"?
I have had that issue before I started caching locally (especially with large mosaics).  It will still transfer and publish the hosted service once the package has been built.
R_
RobertCao
Hi @ThomasGoodridge ,
Were you getting a particular error message when the job stooped? And where is your MD stored on your end? (Local file geodatabase or SDE) If you test publishing a smaller MD with less levels of detail, are you able to publish your MD to AGOL without any issue?
Rob
ThomasGoodridge
I was able to share them with less detail, but they're historical aerial photos and we need to be able to see changes to a property over time at a building level. The project is stored locally.
RhettZufelt
R_
ThomasGoodridge
It's online now, thank you. But its not displaying anything and I don't have the option to build more tiles
