WARNING 100160: Features have invalid geometry
10769
11-21-2022 08:35 AM
Anirban_Banerjee
Error #100160 is occurring while importing longitudinal and latitudinal as shapefile.
I did all the necessary procedures.
Check the screenshot
DanPatterson
MVP Esteemed Contributor
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
an invalid coordinate system was specified according to the help.  Show the table and the inputs to the tool dialog to track down the error
... sort of retired...
Anirban_Banerjee
Dan, A C/S was fed. (Check the screenshot). The inputs are fine as they worked on ArcMap standalone.
The attached ZIP contains the XLS file.
DanPatterson
the points are not in decimal degrees, so you have to specify an appropriate coordinate system.  perhaps it was a projected source like web mercator?  Check
Anirban_Banerjee
Yes, I kept those as Northing and Easting.
I assigned a new P/S from the list but the same happened.
