Visualize the 3D geology using drilled borings
1558
04-16-2024 06:42 AM
GJB
In ArcGIS Pro 3.2.1, I would like to visualize subsurface geology based on geologic contacts determined from well borings. The attached figure shows what I'm trying to recreate but so far no luck.  I imported my table with geologic contact elevations and created a point feature. The points (borings) plot as desired on the ground surface but how do you extrude to negative subsurface values?  Ultimately, I would like to create geologic surfaces, volumes, and/or a voxel layer depicting a buried sand aquifer. Thank you for any insights.
Tags (3)
BobBooth1
Try setting the base height from an expression:
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/define-height-characteristics...
You should be able to use negative values to indicate below surface.
