Visualize surface temperature in 3D building facades
4017
01-05-2016 09:13 PM
ShaliniRamesh1
I have measured data for building surface temperature for a 24 hour period. It is possible to visualize this surface temp data (import this data into GIS Pro or using python scripts)?
Shalini
JawadhHabeeb1
can u explain in what format is the measured data,..?  are there any GeoDataBase Files...?
ShaliniRamesh1
I have the measured data as .txt. Probably can be converted into .csv. The data is hourly building facade temperature based on grid dimension.
Any thoughts on how this can be done?
Shalini
JawadhHabeeb1
With the available data I would suggest you the following links.
Here's a link on how to import CSV files containing points data and display it.
Tutorial: Geocode a table of addresses—ArcGIS Pro | ArcGIS for Desktop
Further you can aggregate the points.
Aggregate Points—ArcGIS Pro | ArcGIS for Desktop
I Had previously done a solar analysis project in 3D.
if you can send me a sample of a data, would be happy to help.
Cheers,
