Visibility Toolset
1102
01-16-2022 10:27 AM
A_n_d_r_e_a
Dear Community,
does somebody know what the requirements for heights storage are? I want to use the sight lines. But it is not working... i already read this link  https://pro.arcgis.com/de/pro-app/2.6/tool-reference/defense/linear-line-of-sight.htm
I also change my fields into double instead of long.
At first I use the exploratory sight lines. But if I open the project again, than after that my sight lines are gone.
I don't notice anything. But what is that?
Should I use some special storagen name for my fields?
I also have changed my features into 3D-Features.
I really don't know...
Thanks in advance!
Greets,
Andrea
DanPatterson
MVP Esteemed Contributor
Did you see the Spatial Analyst topic describing the field requirements for visibility analysis?
Using Viewshed and Observer Points for visibility analysis—ArcGIS Pro | Documentation
see the Controlling the visibility analysis section
... sort of retired...
A_n_d_r_e_a
Puuuh no i didn't see it. Thanks for that! Sounds a little bit complicated, but let's see if I understand something.
Greets,
Andrea
