Visibility of fields after saving a webmap from ArcGIS Pro
1486
04-18-2024 02:14 AM
HelenaKucharzyk1
After updating a webmap from ArcGIS Pro (3.1.0), layer fields are becoming unvisible, even I didn't make any changes in the visibility settings or any changes in the WebMap.
Ed_
by MVP Regular Contributor
In your post you say you did not make any changes to the webmap then what updates did you make to the web map?
Question | Analyze | Visualize
HelenaKucharzyk1
Because I saw the problem with updating webmap and visibility of the fields and I wasn't sure, what was the reason for that, I've tried (just for testing purpose) to update/save webmap without any changes. And had still the same problem.
Ed_
Does the layer have any temporary joins?
HelenaKucharzyk1
No
Ed_
are the layer fields visible in ArcGIS Online?
