View (nonspatial) table's attachments?
691
09-25-2025 10:34 AM
AlfredBaldenweck
MVP Frequent Contributor
I feel like this should be easy and yet I'm drawing a serious blank.
How do you easily view the attachments of a non-spatial table? Best I can come up with is browse through attribute table and check the attachments group on the attribute pane, but that isn't great.
Thanks!
MErikReedAugusta
MVP Regular Contributor
What you're describing sounds like the only way I can think of to use the UI to browse the photos.  It's clunky, but I think since Pro is so centrally built around a spatial database system, all the non-spatial stuff has always felt kinda secondary to me, in terms of UX & functionality.
I suppose the broader answer, though, would depend on what your use case is, here.  For example, we have photos attached to non-spatial tables in one of our field efforts, but that's because those tables are then related to spatial data.  So I can view the photos from the top-level spatial feature and just navigate down the rabbit hole to see the photos.
If you're looking at attachments that have no connection to a spatial feature, then there's a fair argument for viewing them outside of Arc.  Unless it was a live-updating service of some kind, I'd be tempted to periodically download the attachments and view them in my OS' native file system.  As of Pro 3.3, there's now a built-in tool for extracting attachments, but even if I weren't still on 3.1, there's a strong chance I'd build my own tool in a case like this, so the file architecture maintains the hierarchy that I would've wanted from the table, initially.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
AlfredBaldenweck
I was hoping to store some text files in them (it makes sense in context) and then pull them up as necessary. The thing is the pulling them up part.
