view layer with attachments
875
11-06-2024 02:26 PM
temprobertcottreau131313
Is it possible to create a View Layer for a hosted feature layer that has attachments?
I tried to do this but get an 'Unable to Load' error message when I select the view layer.
Has anyone figured out a way around this?  Or is it possible to make a view layer out of a layer with attachments?
ChristopherCounsell
MVP Frequent Contributor
Attachments should be visible on a hosted view layer by default. You can turn them off in the view settings.
https://doc.arcgis.com/en/arcgis-online/manage-data/create-hosted-views.htm#ESRI_SECTION1_3C30E0A91C...
It sounds like something else is going wrong? How did you create the view layer and what are you doing before you get the error?
