View Feature Class dialog box
5307
02-10-2015 08:00 AM
RenatoSalvaleon
How can I retrieve this information in Pro?
ColinZwicker
The layer properties contain this information in ArcGIS Pro 1.0, and they can be view via the source tab.
From a layer\table in a map, r-click > Properties > Source (or Indexes depending on what you are looking for exactly).
Also the fields of the table can be view and potentially altered using r-click > Design > Fields or from the Data contextual tab.
I hope this helps,
Colin
AsrujitSengupta
Which information? Can you please provide more details as to what information are you trying to check in Pro?
RenatoSalvaleon
This ArcGIS dialog box.
ColinZwicker
I hope this helps,
Colin
RenatoSalvaleon
Thanks Colin.  The Design part was easy. I'm still used to using ArcCatalog as a standalone and opening the dialog from the app and not using ArcMap to view the dialog. Some old habits are hard to break..
