Vertical Alignment greyed out
6283
10
06-19-2024 03:22 AM
GISAdministrator8
Hello,
I'm trying to setup a map series and some of the longer map titles require two lines of space instead of one, this leaves titles that require only one line to appear too high instead of centered in the box (see image attached).
This would be fixed if I could change the vertical alignment but this is greyed out for me.
Eugene_Adkins
From the "Element" tab, try adjusting the position for the text from its current position to the middle position. Just an idea.
GISAdministrator8
Thankyou for the suggestion but this has no effect on the text box:
Eugene_Adkins
It may not be ideal but I believe if you remove your text box and then add a callout box to your text (which can be formatted like your text box), the callout box will automatically adjust to the text. This is how I deal with the issue.
GISAdministrator8
Reformatting it to a callout doesn't change the positioning of the text.
I've tried a few things and vertical alignment is available on Straight Text but not on Rectangle Text.
The problem with straight text is that it is in only one line where the font size scales depending on the line length, i also cannot contain it within the designated are/box for the title:
Rectangle text works fine for 2 lines of text as above but when changing to a shorter tile (changing map series) that only requires 1 line the text is stuck to the ceiling:
Perhaps this is too specific to just the way I format the Map title and the issue is purely aesthetic so I will leave it as it is.
Maybe having vertical alignment available in rectangle text can be implemented in future versions, but I wanted to reach out and see if other people encountered this and if they had an easy fix or I was missing something obvious.
TimothyFratta
I'm running into the same issue and I'm scratching my head on how is still not resolved (assuming it's not???)
BrianShepard
I'm also confused as to why vertical alignment isn't available for rectangle text elements. Horizontal alignment is. As a template layout, individual projects may have variable length for source/credit text. I'd like to have the text aligned to the bottom of the element so that additional lines will expand up (into white space) rather than down into my disclaimer. Is there another text element that allows for vertical alignment of text?
GabrielScarcella
I'm also facing the same problem, the vertical alignment options (in text properties) are greyed out.
I tried switching off Maplex, but that didn't work.
It's unclear to me why this does not work from text properties, and how it can be set from the label engine.
Does anybody know what causes the label positioning to be greyed out?
BrianShepard
Thanks for finding that. Looks like after 6 years, it's "Under Consideration" to fix.
