Versioning tab and edit are no longer working on my branch versioned data brought in from portal V3.4.0
1245
01-27-2025 02:12 PM
N8B6688
Just made the update to version 3.4.0 and now all of my branch versioned data that I bring in from my departments online portal are being edited without the benefit of the version management tab, or edit tab.
Everything is working by when I click on the data source, the version management tab does not appear and when making edits to the data I am no longer doing it in an edit session.
Has there been a fundamental change I missed, or do I need to change something in my workflows? Making edits that automatically get posted to the portal is not how I would like to keep operating.
N8B6688
Has no one else had this issue?
George_Thompson
Esri Notable Contributor
I have not seen this unless there is an issue with the Version Management component of the service.
Was the only change that you upgraded to Pro 3.4.x and then the Versioning tab was not showing?
--- George T.
N8B6688
Yes, I have even tried re-publishing new services and the versioning tab does not appear under branch management. When I digress and re-install Ver 3.3 everything works fine.
George_Thompson
Ok, weird. I have Pro 3.4.3 and it works fine for me. Publishing to Enterprise 11.4
What is the version of your Enterprise?
You may want to work with Technical Support on this issue.
--- George T.
