Vector Tile Point Offset
1157
03-18-2021 10:42 PM
SimonHaycock
Designing vector tile basemaps, having trouble with inconsistent point offset distances between Portal / AGOL and ArcGIS Pro
Happy with how it looks in a web map, but when added to Pro a different offset results?
Arc GIS Pro SimonHaycock_0-1616131828730.pngSimonHaycock_0-1616131828730.png
Portal / AGOL SimonHaycock_1-1616131919830.pngSimonHaycock_1-1616131919830.png
Tried many different combinations of 'Preferred offset' (points and mm) and 'Measure offset from' (simplified symbol, feature geometry, and exact feature outline)
SimonHaycock
Pro 2.5.2
DanPatterson
Solved: Labeling in Tiles versus Vector Tiles: Is this the... - Esri Community
similar issue???
a couple of years old but maybe the Enhancement never went through
worth a check before you invest too much more time
... sort of retired...
