Values IDW interpolation do not decrease
2128
06-19-2022 11:43 AM
Wouter
I use IDW interpolation to see how light intensity is spreading across an area. When I perform IDW the values of the intensity decrease but after a certain distance the values stop to decrease. Then all the values are the same but I would expect them to decrease until the intensity reaches the value of 0. Is IDW incapable of doing this?
JayantaPoddar
What is the range of values represented by the points?
According to IDW (Spatial Analyst)—ArcGIS Pro | Documentation, "The output value for a cell using inverse distance weighting (IDW) is limited to the range of the values used to interpolate. Because IDW is a weighted distance average, the average cannot be greater than the highest or less than the lowest input..."
Think Location
JayantaPoddar
Think Location
Wouter
The lowest value is 0.5 so then is makes sense why it will not reach 0. Thanks for your help
