Using "memory\" on Mosaic_to_new_raster
1028
10-31-2022 06:28 AM
koprolith90
Hello Everyone,
using Python I am trying to to store the outputs of the mosaic-to-new-raster function in the-in-memory-workspace for further processing without writing the resulting raster to disc.
The examples provided have only one output parameter. However, mosaic-to-new-raster requires two parameters to define the output: "output_location" and "raster_dataset_name_with_extension".
arcpy.management.MosaicToNewRaster(input_rasters, output_location, raster_dataset_name_with_extension, {coordinate_system_for_the_raster}, {pixel_type}, {cellsize}, number_of_bands, {mosaic_method}, {mosaic_colormap_mode})
Is it possible to use the in-memory-workspace for this functions outputs?
If so, how to define the output parameters?
I am using ArcGIS pro 2.9.3. The support of rasters for "in_memory" was introduced in ArcGIS Pro 2.5 from what i found.
Best regards,
koprolith90
DanPatterson
MVP Esteemed Contributor
output_location
The folder or geodatabase to store the raster.
Workspace
To write to the memory workspace, specify an output dataset path beginning with memory\ and including no file extension—for example, memory\tempOutput.
you can't create a folder in memory workspace or add a file extension, so if you tried and it failed, those would be the reasons.
... sort of retired...
