Using Parse Path to Variable in Calculate Field
1753
08-05-2022 12:22 PM
JohnDavidson
Trying to use the PPName field in calculate field, but it errors each time.
I had added %PPName% in the calculate field code box for Arcade. Is there something else I need to be able to do to be able to add this value to the fields when calculating.?
DuncanHornby
MVP Notable Contributor
This cross posting has been answered on GIS stack exchange here.
JohnDavidson
For some additional context someone had mentioned that I had not added the PPName variable as a precondition to the Calculate field. I did make that change
DuncanHornby
JohnDavidson
@DuncanHornby provided the solution on GIS Stack Exchange
1. Make PPName a precondition of of the Calculate Field
2. Update the calculate field expression to be "%PPName%"
Note: In this instance using the double quote will pass the variable and make it a text field which is passed through as a defined value. You must make sure that the double quotes are used when working with a text field
