Using Nearmap imagery and AI to identify objects
1098
01-13-2022 09:06 PM
RhysDixon
Hi all,
I am hoping to find out if it is possible to use Nearmap to identify objects in ArcGISPro. In particular, I want to identify all retaining walls and create polygons around their extent. Is there any AI-type method to image sample what a typical retaining wall looks like on aerial imagery, and then select other objects that match this to some degree?
I expect that there would still need to be manual checking and deletions done afterwards, but if majority of them can be identified and spatialized it would cut down a lot of work. I thought that perhaps someone may have been able to do something similar to identify roads, waterways etc. in the past.
Thanks for your help!
