Using FeatureSetByRelationshipName in Attribute Rules
1598
03-04-2021 01:55 PM
Z_Knoble
I am new to both Arcade and Attribute Rules. I am trying to create a calculation rule that is triggered by inserts, but my expression using FeatureSetByRelationshipName doesn't seem to be doing anything.
Here is the expression:
var test = FeatureSetByRelationshipName($feature, 'FH_MR_TR_REL', ["COMMENT_"], false);
return test;
I am applying the attribute rule to a table and trying to pull data from a field in a related feature class. 'FH_MR_TR_REL' is the relationship class and 'COMMENT_' is the field in the related feature class that I am trying to pull from.
I didn't get any errors, but the destination field remains null after inserting a new table record. I am sure I missing something obvious; any help would be appreciated.
JimmyBowden
Because FeatureSetByRelationshipName returns a FeatureSet that may have more than one row. You can't just return it you have to get a value from a row.  Assuming you have a one to one relationship you can just get the First one:
if (!IsEmpty(test))
return First(test).COMMENT_
If you have one to many, you would have to apply more logic to decide which one you want.
