Creating a new field from a field that contains multiple values represented as text
871
10-11-2021 12:30 PM
enryb
I'm trying to take a field called Code List which contains the abbreviations for mineral deposits (ex: AU CU PB) either convert this to a field which contains multiple values (one for each mineral) or create new fields for each mineral but am not sure how to go about this.  Any advice would be greatly appreciated.
JohannesLindner
Imagine this is your current data structure:
ID| StringField | CodeList
 1 | abc              | AU CU PB
 2 | def               | AU
To get this structure:
 1 | abc              | AU
 2 | abc              | CU
 3 | abc              | PB
 4 | def               | AU
Use the script I provided in this question.
ID| StringField | AU | CU | PB
 1 | abc              |    1 |     1 |   1
 2 | def               |    1 |     0 |   0
  • for each mineral:
    • create the field
    • calculate the field, switch to Arcade, use this expression:
var codelist = $feature.CodeList
if(IsEmpty(codelist)) { return 0 }
if(Includes(Split(codelist, " "), "AU")) { return 1 } // change mineral here!
return 0
Have a great day!
Johannes
DavidPike
MVP Notable Contributor
Not sure exactly what your data structure is, perhaps a small example would help respondents, but possibly Pivot Table (Data Management)—ArcGIS Pro | Documentation
JohannesLindner
 1 | abc              | AU CU PB
 2 | def               | AU
 1 | abc              | AU
 2 | abc              | CU
 3 | abc              | PB
 4 | def               | AU
 1 | abc              |    1 |     1 |   1
 2 | def               |    1 |     0 |   0
  • for each mineral:
    • create the field
return 0
Have a great day!
Johannes
