Using Arcade to calculate xy geometry.
21885
14
11-21-2019 10:36 AM
AbiDhakal
Hello GIS friends,
Is there an arcade expression I can use to calculate xy values for a point feature? I am using this (return Round(Geometry($feature)x, 6) expression, but it is not doing the work. My field name is Point_X and Point_Y.
Thank you very much,
Abi
AbiDhakal
@Scott
Hey Scott,
I also have a federated service in UTM NAD83 Zone16. I would like to automatically populate x and y fields in decimal degrees as the points are dropped. Would it be possible for us to communicate with emails? Here is my email address: abi.dhakal@forestry.alabama.gov
Thank you,
Abi
AbiDhakal
@ScottKichman
Hey Scott,
I tried your expression. The calculation for Latitude is coming out in decimal degrees which is what I want, but it is not converting right for my original service in UTM NAD83 Zone16. The calculation for Longitude is giving me in meters not in decimal degrees. Please see below the expression I used exactly copying what you had. If you know the modification for what I have to have I will greately apprecite it.
Coordinates
//Latitude
var y = Centroid($feature).y
var originShift = 2.0 * PI * 6378137.0 / 2.0;
var lat = (y / originShift) * 180.0;
lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
return lat
//Longitude
var x = Centroid($feature).x
var lon = (x / originShift) * 180.0;
return lon
ScottKichman
Hi Abi!
I am not sure why its not working. I just tested it and it worked fine. I also used each individual component(lat) and (Lon) separately in a field calculation using the form builder in the (new) Map Viewer. I created a Latitude Field and a Longitude Field and then applied each section as a field calculation in the form.
AbiDhakal
@ScottKichman I'll keep trying, Scott. Also, the difference in mine is I'm trying to convert UTM NAD83 Zone16 to WGS84.
Thank you for your support.
Abi
AbiDhakal
@ScottKichman
Hey Scott,
Earlier, I didn't explain it to you properly. First of all, I'm trying to get Lat/Lon values in NAD 1983 UTM Zone 16N for a point feature and within the same attribute rule trying to convert that to WGS84.
The second one is I'm trying to get lat/Lon values in USA Contiguous Albers Equal Area Conic USGS and then convert that to WGS84.
Thank you,
Abi
