Using AddLayer in a python loop to add layers to a map
3531
01-20-2023 07:56 AM
JohnFix1
I'm running ArcGIS Pro 3.x and trying to add a list of layers to a map. My guess is I'm not getting the python correct for the path to the feature classes in a FGDB.
Here's my python:
import arcpy
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps("MMPK Output*")[0]
aoi = "PA_SCENTRAL"
LayerPath = ("D:\\Mobile Map Package Creator\\DEPLOYMENT_DATA_PACKAGES\\" + aoi + "\\map_data.gdb\\")
LayerList = ("COMPLEXES", "MILEMARKERS", "Zones", "ROAD_NAMES")
for Layer in LayerList:
  Layer2Add = (LayerPath + Layer )
  AddStatus = m.addLayer(Layer2Add)
And here the error message I get back:
File "<string>", line 14, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\utils.py", line 191, in fn_
return fn(*args, **kw)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\_mp.py", line 2217, in addLayer
return convertArcObjectToPythonObject(self._arc_object.addLayer(*gp_fixargs((add_layer_or_layerfile, add_position), True)))
ValueError: D:\Mobile Map Package Creator\DEPLOYMENT_DATA_PACKAGES\PA_SCENTRAL\map_data.gdb\COMPLEXES
DanPatterson
MVP Esteemed Contributor
did you try
addDataFromPath (data_path)
The paths are as follows
aoi = "PA_SCENTRAL"
    print(LayerPath + Layer )
D:\Mobile Map Package Creator\DEPLOYMENT_DATA_PACKAGES\PA_SCENTRAL\map_data.gdb\MILEMARKERS
D:\Mobile Map Package Creator\DEPLOYMENT_DATA_PACKAGES\PA_SCENTRAL\map_data.gdb\Zones
D:\Mobile Map Package Creator\DEPLOYMENT_DATA_PACKAGES\PA_SCENTRAL\map_data.gdb\ROAD_NAMES
.  Are they all in that gdb in that path
... sort of retired...
DanPatterson
did you try
aoi = "PA_SCENTRAL"
JohnFix1
Dan, I thought I did try it without success. But I just tried it and it works! Thank you.
I did:
aoi = "PA_SCENTRAL"
  AddStatus = m.addDataFromPath(LayerPath + Layer)
JohnFix1
I do have a question for you. In my layers list, I also need to include a network dataset. It's in the same FGDB. The feature dataset is "My_Network" and the network dataset is "My_Network_ND".
I can't seem to figure out how to include this feature in my loop.
