User Interface Graphical Error
2422
02-02-2024 12:09 PM
ScottyMartin1992
Recently, within the last few weeks I have been getting strange graphical errors on the UI of ArcPro and I cannot seem to fix them. (Images attached)UI Glitch 1.JPGUI Glitch 1.JPGUI Glitch 2.JPGUI Glitch 2.JPG
I have followed the technical support which directs me to change the display options, none of the changes has made a difference. I have updated graphics drivers, windows and ArcPro.
I have found a similar post at the following location:
https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-2-8-ui-glitch/m-p/1111911#M47271
The solution is solved with uninstalling the Alienware command center, however i have never had that software on my system.
System specs are:
Intel Core i9-10900k @ 3.7GHz
32GB DDR4 Ram
NVIDIA GeForce RTX 4070
Windows 10 Home - Vers 22H2 - Windows Feature Experience Pack 1000.19053.1000.0
Any help on this issue would be greatly appreciated.
Tags (3)
Robert_LeClair
Esri Esteemed Contributor
Strange!  One solution I saw in the internals was to disable hardware acceleration through the Registry Editor.  You can try that workflow via this link.
Robert_LeClair
ScottyMartin1992
Typically the issue is not happening today, it does seem to happen sporadically so the next time it happens I will give this a try and let you know the outcome. Thank you for your suggestion.
ScottyMartin1992
So the problem just occurred again, I tried your method and it seems to have solved the issue, so thank you very much!
I think it may have to do something with my partner playing old games on my PC like the original RollerCoaster & Zoo tycoon games. I uninstalled them and have not had this issue for weeks, I then reinstalled the games on a different user profile this weekend and the problem returned the next time I booted up ArcPro after she played one of them.
ThomM
I had a similar, yet slightly different issue.  My interface looked like it was erroring out (like it had stopped responding), or would appear with different colors:
Putting the disable Hardware Acceleration in regedit also fixed the issue.  I hadn't had any issues after using this software for years and then it started today (26MAR24).  I wonder what changed?
