Use Attribute Rules to remove text from a field
9148
13
11-05-2021 09:02 AM
JustinBernard1886
Hi all,
I am extremely new at using attribute rules and Arcade for ArcGIS Pro, and I need some help on what I am sure is a simple process.
I have a column filled with text like this, "R4-52" and "H-R4-52" What I would like to do is use arcade to populate a new field where the output will be "R4", basically removing the dash and any characters before and after the dash. I know the replace function can be used to do this, but I wasn't able to find any examples.
Can someone help with this?
Much appreciated,
Justin
JoeBorgione
Five minutes in the ESRI Arcade playground and I came up with this:
var name = ' R3-1';
Console(name)
var nameArray = Split(name,'-')
Console(nameArray)
var arrayLength = Count(nameArray)
Console(arrayLength)
if (arrayLength == 2) {
    Console(nameArray[0])
The Console() function is like the print() function in python, but it only works in the playground.  This is nothing more than python logic in Arcade...
That should just about do it....
JustinBernard1886
Hi All,
So I was able to find a solution that fit my needs. Thanks so much for all the help!
Justin
JoeBorgione
Care to share?
JustinBernard1886
Here:
(I did not write this)
var ZoneCodeName = $feature.CENTROID;
var ZoneCodeFndDash = Find('-', ZoneCodeName, 0);
var ZoneCodeFndLBracket = Find('(', ZoneCodeName, 0);
var Char1 = Mid(ZoneCodeName,0,1);
var Char2 = Mid(ZoneCodeName,1,1);
if (Char1=="H"){
var ZoneCodeCount = Count(ZoneCodeName);
var ZoneCodeName = Mid(ZoneCodeName, 2, ZoneCodeCount);
if (ZoneCodeFndDash!=-1){
var ZoneCodePre = Mid(ZoneCodeName, 0, ZoneCodeFndDash);
return ZoneCodePre;
if (ZoneCodeFndLBracket!=-1){
var ZoneCodePre = Mid(ZoneCodeName, 0, ZoneCodeFndLBracket);
return ZoneCodePre;
return ZoneCodeName;
return ZoneCodePre;
return ZoneCodePre;
