Update Z Values for multipatch
760
12-19-2022 04:06 AM
Labels (3)
salsabeelaBadran
Hello everyone ...
I am trying to updata Z-Values For MultiPatch But I can't .
I Published  it in Zero level ,Now I am trying to raise it  to the Real Level  from the reigon's  DTM
thanks in advance
Andrew--Johnson
You can set the multipatch elevation setting to "On the Ground" from the layer properties elevation page and then run the Layer 3D To Feature Class tool and the output will burn the Z values from the DTM into the multipatch (assuming the DTM has been added as an elevation source to the Ground elevation surface layer).
thanks,
Andrew
